Power issue
VPasculli
Good Afternoon,
While using a tire inflator to inflate one of my tires on my 2005 Lincoln Aviator the unit suddenly stopped. I checked the fuse and the fuse is still good. Checked the unit in another cigarette lighter and it works fine. Any ideas what it may be?
Thanks
mark95man
Good Afternoon,
Thanks
QUESTION: How did you check the fuse? I use a volt meter as the blown part could be out of sight. If the pump worked in another outlet, I would think the fuse is the issue--try a new fuse and advise.
Slick Fan
601
6
Utah
True, sometimes a fuse can blow in a spot other than the "U" shaped area, leaving the fuse appearing still good.
VPasculli
I tried another fuse and still have same result
mark95man
OK, how many cigarette lighter outlets does your vehicle have? In my TC & other Lincolns, each outlet has its own fuse. Did you check the correct fuse? Usually the second outlet has its fuse in the engine compartment fuse box.
