Old Blue '92
90LSC_CT
Trans shuffle?
Valve body updates in \'90.
SilverFox
Trans shuffle?
You asked....:D
AOD was produced from 1980-93
1984-86 Cast drums, 7 tooth speedo output (somtimes), 3/4 STEEL (yuk) case bore accumulator, STEEL 2/3 case bore accumulator.
1986-89 Cast drums, 7 tooth speedo output (somtimes), 3/4 Plastic (still yuk) case bore accumulator, Plastic 2/3 case bore accumulator.
1990-92 Stamped steel forward drum (91-92 for sure), NO 3/4 accum (yeah), new VB (yeah), Plastic 2/3 case bore accumulator.
1992 the AODE was introduced and ONLY put in 5.0/3.8 stang 94-95. Also in 4.6 92-94 in TC/Conti and were a POS!!! But had upgrades. Stamped steel dirrect/forward/rev drum and 2\" OD band.
1994 4R70W introduced with No governor feed holes in the tailshaft.
The M7/TC/COnti/Police/Truck AOD\'s are 1\" longer at the tailshaft than the STD length versions.
AODE/4R70W is longer at the BELLhousing than the STD AOD and is the EXACT same length as the Long AOD...this makes it a SUPER easy upgrade for M7.
re-Markable LSC
Trans shuffle?
So you can put a 4R70W bellhousing on a Mustang AOD and it will plug and play in a Mark 7?
No wait... that\'s not right, build an AOD in a 4r70w case? WTF? I\'m confused. (what else is new).
SilverFox
Trans shuffle?
You sure are.....
Last interchangable bell on FORD was the C4 and T5......AOD/E/4R is integrated, no swaping allowed :) There is only ONE existing 4R70W that will bolt to the 5.0 and that is the 4.2L truck trans.
You can put 4R guts into an AOD and gain a better acceleration due to the wide ration gearing of the planetary. This is becoming commonplace...but is funky to control with the hydrolic VB. IMHO a person should invest in an aftermarket VB like Lentech/PA if this done.
Chip89LSC
Trans shuffle?
So the 4.2 truck AODE/4R70W *will* bolt up to the mVII 5.0,*and* is the proper length (longer) to fit??:chin:
SilverFox
Trans shuffle?
Yes...and all you need is the Baumann TCS controler to use it - $400! and a new yolk or AOD tailhousing, and possinly flexplate.
