No lights working, no windows or sunroof working. Please help!
Daddymackz
I have a 97 lincoln towncar I just bought from my first boss. I loved this car from I first bought it. After getting the car, I noticed that none of the lights are working;no headlights, no parking lights, no interior lights. Additionally, none of the windows or sunroof is working. I checked the fuses and relays which appeared to be in good condition. NOTE the car is running like a dream! I need help please! Anyone else ever experienced this issue with their lincoln?
Brian J. Patterson
52
Northern Illinois
Have you checked the fuses and relays in the high current fuse panel? It's located under the hood on the left-hand fender apron. Start with fuses A and F. In addition to the fuses themselves, check for corrosion on the fuse connectors, and general condition of the panel itself. You may need to re-seat (remove and replace from the panel) one or more connectors into the high current fuse panel.
Daddymackz
Thank you Brian! I will look into this right away!
estreet7
Sounds like you may need a Lighting Control Module if that year has one. If the fuses and relays are ok check that. Match the part numbers from a junkyard or Ebay! They are easy to change!
