New member - questions
Uwe
I recently purchased a silver 2001 Lincoln TC Executive with 69K miles on it for $2200 from a widower. I just found this forum and it looks like a very informative place. I've really come to like this car very much other than the gas mileage but I'm getting an average of 22.6 mpg on country roads which all things considered isn't that much worse than what my wife gets on the 2014 Odyssey.
I discovered, as many people have, the leaking issues. I believe I got the passenger side corrected but I'm still dealing with the driver's side. I've seen the threads about it resolving the issue but how in the world do you get the carpet pulled back? I looked for screws in the molding but I don't seen any obvious ones. I searched about carpeting but haven't come across any addressing this.
It's too big to park in my garage so it has to sit outside. Is there a car cover anyone recommends? It is not my daily driver but I want to provide some protect from the elements.
Thanks,
Uwe
4,394
118
Welcome to the Forum.
Do you need info for driver side front and rear? I will see what I can find.
I have no experience with car covers, but from covering other things the cover needs to breathe or you will get condensation on inside that will cause rust.
Uwe
Driver's side please.
I live in the mountains of NC. It rains a lot here so that would be a consideration regarding covers.
4,394
118
There is no service procedure for carpet removal. So hopefully someone with experience will chime in on what you have to do.
As far as the driver's side front leak is concerned; read this link:
Water in Drivers Side Floor Pan
I have had the same problem with damp/wet carpet in driver's floor pan. I implemented Mafatone's" solution and since then my carpeting is dry after rain. I used 7/16" O.D. clear fuel hose to insert into the driver side wiper cowl drain hole; securing it with RTV. I didn't pull up the carpeting.
25
Hi Uwe. Concerning a car cover to protect it, I can recommend "California Car Cover" for a variety of car covers: California Car Cover Co. Official Site | Custom Fit Car Covers & Accessories for New & Classic Cars On Sale
I've purchased two car covers from them, along with a variety of smaller items over the years.
Give them a call and tell them what specifications are important to you (waterproof etc). And as Town mentioned, even a waterproof cover needs to be "breathable". A good cover prevents moisture from penetrating from the outside, but will allow moisture to evaporate from the inside. It must also have a soft and non-abrasive underside, to avoid damaging the paint finish. This is why we can't just cover our cars with a giant sheet of plastic.
As far as the carpeting, I am not sure how extensive a removal you are trying to achieve. However, most cars require the front seat/seats to be removed for a full removal.
Keep us updated and good luck with your drying and research.
Uwe
I appreciate the responses.
Leak - I had cleaned out the driver side drain earlier but the water is still coming in. Did you have to take out the cruise control module to install the 7/16 tube? I'd prefer this to be as little invasive procedure as possible. I was going to ask if the RTV was enough to secure it but I see it's an adhesive too. I'm going to do this weekend to see if it resolves the issue.
Car cover - I looked at the California car covers. I looked at a variety of covers and none came in under $200. My wife gave me "the look" ...had it been a pocketbook THAT would have been a different story. She's giving me a $100 budget on the cover. I'm sitting there the whole time thinking I bring home 80% of the bacon and you're driving a vehicle that costs 16 times the cost of this car...
It's raining hard here today. I'll be out there with a shop vac tonight. Hopefully for the last time!
Maybe I can send some pics. Can you upload them straight to the site or do you have to use one of those imaging storage services first?
Thanks again!
/QUOTE]
I had no interference from any type of modules or cables (2007 Town Car). The 7/16" tube was about 2 ft long which I routed down behind the driver's side wheel housing. Used DAP Max silicone. Here's a picture.
25
Hi Uwe. Not sure how much you can discuss the point with your wife...but you will not a get a good car cover for $100. And a low quality car cover can actually do more damage than it prevents.
However, I understand completely. You have to live with both your wife and the car, but she can talk.
Keep us updated and good luck with whatever you decide to do.
4,394
118
Uwe has a 2001 model that uses a servo on the bulkhead near the throttle cable and the drain. The 2007 does not use the sevo for cruise control so the area is more open.
It is easy to upload pics to this site. At the bottom of reply box is a box that says "attach files" so click this and you will be connected to your computer directories. Select your pics that should be 400kb or so and upload them.😛
Uwe
Here is a picture of where the drain is. The box with the gray top is, I believe, the cruise control unit(?). It is pretty close to the drain hole and makes putting a hose under the drain a bit tight. It
looks like there are two bolts securing it. I think if I took those out and scooted the CC unit forward a little it would give me enough room but I am not sure if the black rod going off to the left of it can detached or if it would bend enough to move the unit forward.
As for the car cover I may bide my time and wait until she wants or buys something and then pull the trigger on it and ask for forgiveness later.
4,394
118
The rod at front left of the cruise control servo is the throttle cable. It may have some give to move the servo forward but when you move the servo back you will crush the new drain hose. With the 2003 and up models the drain is about over the throttle cable which exits from the bulkhead and goes up so water can get on the cable and drain down the cable to the seal which may fail and allow water in the cabin. That may not be the case with the 2001 model due to the throttle cable attaching to the servo. It looks like you have some space to the right of the servo just in front of that rounded metal piece on the side panel at bulkhead if you want to mount the hose.
Uwe
I was able to unsecure the CC and move it out of the way a little bit and install the tubing. It's going to rain today so it will get tested.
aditya-mishra
Thanks again!
i got my car cover 2 years ago from carcover.com
i paid 135 and its been holding good. go check them out.
Uwe
The water leak is about 95% better. There still seems to be a little moisture getting in but its not flooding bad enough to want to build an ARK. I want to get into clearing the drain holes but I can not for the life of me get the passenger side windshield wiper off. I don't want to break the old brittle plastic surrounding the windshield wiper base.
I just looked at carcover.com 16443 reviews on the Gold Shield cover for $139 cover. I'm running it by the Mrs. to get her almighty approval. She already told me earlier my Christmas was looking bleak at the moment. Thank God she can't read minds. Though I suspect my facial expressions transmit more than enough data to doom me.
