Lincoln MKZ 2012 Tail Lights not working
tonymora7
My tail lights don't work, and the license plate lights don't work. I replaced the bulbs on the license plate lights and they still don't work. I can't locate bulbs for the tail lights. The brake lights and turn signals work. Any idea what is the matter?
1,382
Hi tony and welcome to the Lincoln Forums. First step would be to check fuses. Fuse diagrams, list and fuse box locations are in the Owners Manual Index under "fuses".
If you do not have your hard copy, you can download the PDF versions here: https://www.fleet.ford.com/parts-service/resources/owner-manuals/
Bulb lists are also in the Owners Manual. But I believe they are all LED and may not be individually replaceable.
tonymora7
Thank you so much! It was the fuse!
