jesse.srq
- Jul 8, 2020
- 32
- 7
- 8
I've certainly enjoyed the last few months since I purchased my '19 Continental. When I first bought it, one thing I did right away was to customize module settings with Forscan. My previous experience with Forscan was on a '17 Fusion Sport which allowed me to really take customizing to the next level. Everything from blinker flashes, to instrument cluster settings, exterior lighting, to APIM I could change my way. Heck - I could even change the temperature degree of the heated steering wheel if I wished.
The only hiccup that I've run into is that there is not much support out there in the way of As-Built programming on the Continental. With the Fusion, there was an overabundance of information which is expected considering its popularity, but there's almost nothing for the Continental, and for Lincoln vehicles in general. Again, I shouldn't be surprised, but if anyone knows where I can dig up more information, it would be most helpful.
So far the only changes that have worked have been the following. These changes come from Fusion As-Built programming...
Thanks!
- Ability to access functions on APIM not available while the vehicle is in motion. Example being to input addresses in Navi while driving.
- Bambi mode which allows low beams and fog lamps to illuminate at the same time as when high beams are activated.
- Horn honk deactivated when exiting vehicle with the key while engine running.
- Auto blinkers from three flashes/clicks to custom number.
Thanks!
