Manuelb
- 0
- 1
I just bought a Lincoln MKT 2018 and the previous owner forgot the code for the keyless entry keypad. Can anyone tell me where in the car is the keypad code located for the 2018 Lincoln MKT?
I think the OP will get stuck at Step 1 unless he can find the factory code in the owner's manual in a card as redgemini said.![]()
How To Reset Lincoln MKT Keyless Entry Keypad Door Code
How To Reset Lincoln MKT Keyless Entry Keypad Door Code - This procedure should apply to the third generation of Lincoln MKT.seventrumpet.com
Do u really need this anyway? If u have your fob on u u can gain entry anyway??I just had this same issue - $99 asking from the dealership, a real ripoff. You can easily find it yourself - the code is underneath the steering wheel on the Smart Junction Box. There is a cover above the gas & brake pedals, with one hex screw on the right side and one plastic retainer on the left side. Pop both off, remove the cover and shine a flashlight down there. There will be a white sticker with the code written on it. It may end in a letter, just ignore the letter and copy down the 5 digits you see. Replace your cover and you're good to go. Should take you all of 2 minutes to do (most of the time spent trying to pop off those stupid plastic retainers)
Easy! Dealership is profiting the full $99 from you if you take it to them.
I never thought I'd use it. However... since I only have one fob for mine, using the keypad has been more of a precautionary thing. My mom locked herself out of her MKX while at a store one time. She opened the hatch before unlocking the doors, put something in the rear, and didn't realize her keys also landed in the hatch. After closing the hatch is when she had that "oh, sh*t!" moment. Luckily, she had a 2nd fob at home, but she made sure to memorize the code after that.Do u really need this anyway? If u have your fob on u u can gain entry anyway??
Do u really need this anyway? If u have your fob on u u can gain entry anywayI just had this same issue - $99 asking from the dealership, a real ripoff. You can easily find it yourself - the code is underneath the steering wheel on the Smart Junction Box. There is a cover above the gas & brake pedals, with one hex screw on the right side and one plastic retainer on the left side. Pop both off, remove the cover and shine a flashlight down there. There will be a white sticker with the code written on it. It may end in a letter, just ignore the letter and copy down the 5 digits you see. Replace your cover and you're good to go. Should take you all of 2 minutes to do (most of the time spent trying to pop off those stupid plastic retainers)
Tks for getting backI never thought I'd use it. However... since I only have one fob for mine, using the keypad has been more of a precautionary thing. My mom locked herself out of her MKX while at a store one time. She opened the hatch before unlocking the doors, put something in the rear, and didn't realize her keys also landed in the hatch. After closing the hatch is when she had that "oh, sh*t!" moment. Luckily, she had a 2nd fob at home, but she made sure to memorize the code after that.
I do occasionally use mine. If I have to go out to the car to get something, and don't have my keys on me, I use the code. Also, if the key fob flakes out (dead battery etc.), you can still get in, and start the car. Yes, you could use the key to get in, but most people forget the key is even part of the fob, or they don't even know it exists.
Tks for getting backhappy new year to u and your family
