How to get to seat belt chime module in 1979 Lincoln Town Car
john116
Hi - how do I get to the seat belt chime in a 1979 Lincoln Town car? I believe it's located on the left hand side of the glove box, but how do I get to it?
Thanks,
John
srod58
on the backside of the glove box in the middle, white box about 1in thick by 5 wide, it' up in there abit. mine is a 79 town.
srod58
update, got mine out and repaired and back in working.
if look under the dash at the middle of the glove box you should see a white box about 2x2 with a green plug, to the pass side of it there is screw. on the driver side of the box there is a white plug, squeeze the bottom sides to release, screw under plug, once both screws are out a plate with white box. low fuel switch, and seat belt chime, will drop down, remove one more screw holding wire harness, unplug the plugs and should be out.
