Hid headlamp bulb
Rongold
GOOD DEAL !!! Did you ever get those torx screws loose on the bulb retainers ??? You mentioned that they were very tight trying to get them loose. Don't use a screwdriver type torx tool---Use a torx socket tool that fits on a 1/4" ratchet---more twisting power.
RON
Simonsays
RON
Hey Ron, no, ill worry about those after i repair my front suspension. Lower control arms are shot...
rlsullivanjr
The torx screws in the 2011 are size 10. I found the socket version of the torx to be too wide to remove the screw closest to the fender. The other one came out easily. I had to put the car back together to go get a torx screw driver. Fortunately it's easy to take out the air filter to get better access.
The passenger side will come later after I get my rejection sticker removed.
