Help
Dmcmullen
01 LS w the v8, re0laced num 4 coil pack and plug l rough idle code fuel lean cleaned maf sensor no change. Any help appreciated.
Dmcmullen
Check eng light came on, did a scan and 1 st code said misfire num 4 cylinder, replaced coil pack and spark plug. 2nd code showed fuel too rich and too lean, cleaned maf sensor and no change. Runs good on hwy slight shake at full stop.
