help me diagnose my issue plz
38
Hi cpark, First thing you should do is check the fuses for those accessories. You can find the fuse box locations and fuse numbers for those accessories in your Owners Manual by looking in the Index under "Fuses". After you check the fuses, post back and someone may be able to help.
Considering you have another post concerning a no-sound issue with a new sound system you just installed, it would be within the realm of possibility that the sound system and window moonroof issues may be related.
Also, it probably would have been better if you had posted both issues together in one thread here, instead of hijacking/piggybacking on someone elses thread about your stereo issue.
cpark77
I checked all fuses and relays everything is good there. I also have reinstalled the factory radio system as the aftermarket system didn't come with the proper wiring harnesses to work with the Lincoln. Radio works perfectly fine still the front windows or panoramic roof doesn't work. The rear door windows work fine. I'm stumped.
baylensman
cpark77
Issue has been resolved it was the fuse number 41 a 15amp fuse for the Delayed accessory function for radio and lock switch illumination ('07-'09), Ambient lighting ('09), Automatic dimming rear view mirror ('10).
I didn't check that one because it wasn't labeled as anything to do with windows
baylensman
