heated seats
2013 Nav. heated seats are not working. the control light turns on then immediately turns off. Where do I start? Thanks
Hi anitamatsu. For starters, check the wires and connectors/plugs under the seats. If all is well there, another problem area can be a broken wire in the seat heating element. To check that, you usually will need to remove the seat and seat cover to look for a burn spot.
Hopefully someone with personal experience can also jump in with their own findings.
Good luck
anitamatsu
Good luck
Thanks, appreciate the direction.
