Good power upgrade??
hhc70
LSC guage cluster in a Bill Blass?
Has anyone done this? Is the wiring all there? The car is a 90.
Bill89LSC
It\'s been tried and it\'s not worth it. I think you have to change the whole harness and there were many other issues getting all the gauges to work. IIRC it never did work correctly.
Ricks90billblass
It is a royal pain to do this, you have to replace the oil and temp sensors you have to get a different harness to fit the guage cluster, and last but not least. You have to replace the fuel sending unit in the tank.
I found a combo tach and guages unit at summit racing, http://store.summitracing.com/partd...part=SUM-800104&N=700+400304+115&autoview=sku
Part# SUM-800104
and J.C. Whitney
http://www.jcwhitney.com/autoparts/...s-10101/Ntk-AllTextSearchGroup?Ntt=Tachometer
I have the summit unit for my BIll Blass, I just have to install it.:idea:
hhc70
Well then I guess I will forget about that idea! :(
Thanks for the response.
LSCSE9091
I have done this conversion and I found that i only had to replace the main dash harness and everything worked fine for me.
