Fog lights switch location
739
Where is the fog lights switch on 2004 aviator
Hi G. I am not 100% familiar with fog light switch placement in the 2004 Aviator.
However...the usual fog light switch type and placement in Lincoln vehicles is one of two types: There will either be a separate switch located right next to the headlight switch...or if the headlight switch is the turn type, you will pull the switch out to activate fog lights.
Fog lights will normally not activate if high beams are on.
Take a look at your headlight switch area and give those two suggestion a try.
