Factory default
Denise
My Lincoln dealership lost the preset code for my keyless entry on my 2019 Lincoln nautilus. They want to test the door apart in order to program it. Does anyone know how I can obtain the code?
Denise
Thank you,a call is better than taking my door and dashboard apart, which I am not going to do.
23
Hi Denise. Do you have both keyfobs to your Nautilus? Assuming you do, the instructions for how to retrieve the keyless entry code are right in your Owners Manual, beginning on page 70. As long as you have both keyfobs, you can retrieve it yourself. The Dealership should know this.
23
It worked !!! Thank you!!
Hi Denise. You are very welcome! Happy it worked out for you.
And it is ridiculous that the Dealership people you spoke with did not know this. This has been the procedure for several years now.
Good luck with your new Nautilus.
