Engine swap
Shoogzy
I have a 02' LTC. I also have a 05' CVPI. I am needing to put the interceptor motor in the town car. Both vehicles are complete. Town car has blown engine. Will it work? Any advice will be tested and then possibly appreciated.
4,359
112
Welcome to the Forum.
The 2005 and up Panthers used different electronics which included throttle by wire. You would have to change the throttle bodies over to use the throttle cable setup and associated electronic parts for the 2002 Town Car. The Performance improved 2005 engine may not be as powerful with the 2002 electronics however.
The Mercury Marauder site: The Garage - MercuryMarauder.net Forums and the CrownVic site: Crownvic.net | Forums powered by UBB.threads™ have members that would likely be able to answer your question accurately because they may have done the swap. CrownVic site is very knowledgeable.
