Driver door won’t open
JDH
33
Tried to enter my 2017 Continental Reserve and my door wouldn’t open. After climbing into the drivers side thru the passenger side, I discovered the door wouldn’t open from the inside either. This includes using the door latch on the door. Very disappointing, I truly want to like this car but, this is unacceptable!
MarkX
441
166
Obviously, there is something more serious than just lubrication going on here. I hope you will be taking this to another dealer for a more thorough evaluation of what the problem is. Had the car been hit, by any chance?
jhartz
Jan 19, 2018
328
114
Virginia Beach, VA
Door handles and locks are a known problem on 17 Continentals: all fixed/replaced under warranty.
If the fob works, roll the window down by holding the "unlock button" then reach in and pull the lower emergency release on the driver side door.
G-550354
Door would not open using the inside latch
jhartz
Jan 19, 2018
328
114
Virginia Beach, VA
Couple more tricks before you get it truck lifted to the dealer: if you can get to the hood release, open the hood, disconnect the battery cable and wait while the capacitors empty (about an hour) or touch the negative cable to the positive post and reconnect to see if the locking mechanism has reset; remove the key from the fob and try to unlock it from the lock on the Continental logo, again, to reset the driver side locking circuits.
djammons
6
4
Any update on what the issues was? My wife has a 17 Continental but so far no issues with the doors. I just bought a 2020 new one for myself.
JDH
33
It’s working correctly now, I’ve read where there’s been trouble with the door actuators preventing doors from opening.
In my case, I believe what happened is. My door didn’t pull itself shut all the way as it’s supposed to. I believe it’s called E latch or easy close.
So the car thought the door was open when it wasn’t. I was getting the “Door Ajar” message on the dash also. I couldn’t open the door from outside, inside and even the inside lever didn’t work. Very frustrating. I had to disconnect battery to reset everything and now it’s working again. Truly a PITA.
jhartz
Jan 19, 2018
328
114
Virginia Beach, VA
I think you need to take it to the dealer -- the 2017s had a recall for door handle/lock issues. As I understand the recall order, it will be covered even if outside warranty.
JDH
33
As we all know, the dealership won’t replace a part if its working. At this time it’s working.
jhartz
Jan 19, 2018
328
114
Virginia Beach, VA
Given this is a recall under warranty, it might be worthwhile to call the dealer (or Concierge) for their opinion. When I took mine in, it was working (the pawl would stick in 'locked' position -- they replaced all four . . .
JDH
33
Is this a recall under the new car warranty which is four years 50,000 miles? Which mine is no longer under. I did purchase the premium care warranty but I’m finding out that there’s a lot of fine print that they do not cover. As with this reverse light issue that I’m currently dealing with.
jhartz
Jan 19, 2018
328
114
Virginia Beach, VA
Make the call
BSmith81
33
37
Jonesboro, GA
If the door latch recall is open under your VIN, then warranty has nothing to do with it. It's labeled by Ford as a safety recall and has no expiration and can be done at any time. The recall will replace all 4 door latches with new latches. Give your local Ford dealer a call and give them the VIN and they'll check to see if the recall is open for your car.
JDH
33
What if my car’s vin is not open for this recall? Now my passenger door is acting up. Have to keep trying to open the door before it finally opens.
BSmith81
33
37
Jonesboro, GA
Then you'd have to get a diagnosis to find out what's wrong. Usually the standard for a diagnosis is one hour of labor. Once they determine what all is wrong, then they'll price everything out with parts and labor to replace the parts and tax.
jhartz
Jan 19, 2018
328
114
Virginia Beach, VA
JDH: Seriously, only the dealer (or a Lincoln rep) can answer your question. YOU have to contact them. If it is a 2017 vehicle, there was a cross the board warranty recall. They replaced all four door openers, for me, for Town, for others. Only a dealer can work this for you. These locks -- for the 2016/early 2017 build were bad. They fixed them, for free, . . . . Please make the call!
jhartz
Jan 19, 2018
328
114
Virginia Beach, VA
I can't seem to find the thread, which I think Town opened, that first discussed this issue. Search tool is not working for me.
CARR142
195
CHERRY HILL, NJ
ElViktor
2017 Select 3.7
I have a 2017 continental Select I’m going through the same thing starting yesterday. Driver door won’t open from outside nor inside, nor will the Manuel release latch open the door. I tried to key by inserting it in the hiding spot on the right side CONTINENTAL emblem but that didn’t work either. I haven’t tried disconnecting the battery yet but I don’t want to cause any electrical damage.
