• In the 1980s and 1990s we used AOL and Usenet. In the 2000s there were forums and message boards. In the 2010s - and until the very near future - social media. Something new is coming for Lincoln owners... Become an early adopter of what's next by SIGNING UP HERE. Your email address will not be sold or used in any way other than us communicating more details as we prepare for launch - and we will not communicate often.
Carwash Water Coming Out Of Spoiler
Jun 13, 2021
89
When I took mine in for the seat pan repair yesterday I mentioned the excessive runout to the service advisor. She said they all do that and it is a common complaint. My car wash doesn’t have compressed air. I have angled the lift gate half open while I dry the rest of the vehicle and use the vacuum. I open and close it several times and take the car wash vacuum to the areas where the runout is most persistent.
I wanted to touch base with you concerning the excessive runout of water of both sides of the lift gate and spoiler. I mentioned this to my dealership and they said no one else has complained. I said 'really???' it's a known problem on the forum. They said they'd have to make an appt with a 3rd party company that deals in 'leaks'. This issue doesn't 'leak' into the vehicle, it runs down both sides of the lift gate trim and down the spoiler. I really don't want a 3rd party looking at it since it's a design issue. And anyway, why would they need someone to take care of 'leaks'. Not sure if I've explained this well enough but since you have this issue could you tell me your thoughts or how you've handled? Thank you!
RedHoncho
476
360
Marysville, Ohio
I mentioned it to my dealership service department when I took mine in for a TSB. The service advisor told me it was a very common complaint. I have started opening the hatch halfway as soon as I’m out of the car wash. I dry the exterior and vacuum the interior before I lower and raise the hatch several times. My biggest gripe is it isn’t just water coming out but detergent as well. Even after the vehicle sits it continues to run out for over an hour. It’s maddening.
Jun 13, 2021
89
Min
RedHoncho
476
360
Marysville, Ohio
My carwash doesn't have compressed air. I have taken the vacuum to the offending areas to suck out as much water and detergent as possible but it continues to drain out.
HBcorsair
80
69
After taking the time to clay bar, detail and put a graphene ceramic spray coating on my pristine white ‘21, I don’t think that I would be able to run it though a car wash to even see if I had an issue. Washing it by hand has yielded no problems & it’s actually been pretty good therapy.
theone1211
hi..carwash is a bit problem for me..check on google.
bigblue2007
205
77
Boston, MA
No swirl o magic for me. Hand wash or touch less.
kingdre
481
195
Atlanta, GA
I think I understand why some folks see water. I got my truck 4 days ago. In the overall inspection once I was away from the dealer, I noticed two 'slots' with the trunk open that are empty... one is on each side.. like above the inside lamp. I also noticed inside the door between it and the fender, there is insulation but no cover.
bigblue2007
205
77
Boston, MA
I think I understand why some folks see water. I got my truck 4 days ago. In the overall inspection once I was away from the dealer, I noticed two 'slots' with the truck open that are empty... one is on each side.. like above the inside lamp. I also noticed inside the door between it and the fender, there is insulation but no cover.
Truck?
