Brake light switch issue 2006 Lincoln town car signature
DamItKev
I recently replaced the brake light switch for my Lincoln due to the brake lights flickering on and off when braking. Now that I replaced it the car is stuck in park and the brake lights won’t turn on when pressing down the pedal. I can manually move the switch and it will move out of the park position and brakes engage but brake lights will stay off.
wihr
68
21
So, replace the switch. How much can that cost?
DamItKev
I did the replacement yesterday but now the lights won't come on at all. I can manually move the switch and it will turn the brake lights on. Pressing down on the brake it's not working.
Norms1stTC
1,056
I'd suggest you get a different switch , that one may be faulty, have you also checked all fuses and shift interlock solenoid, the brake switch I believe controls these also. I'd get your manual out and see if you have blown fuses and a bad relay. Good Luck.
1,703
838
Phoenix, AZ 85008-1418
Test the new switch.
