Backup Camera Install
Thread starter #22
More Weight Reduction
[quote name=\'CaptainZilog\']Aluminum heads will net you about 50-60lbs. Aluminum driveshaft was worth 10+lbs.[/QUOTE]
DS is probably close to 20 if you include the stock cardan and xtra joints. Gotta get these cars on a diet.
Thread starter #23
JoshMcMadMac
[quote name=\'NYC LSC\']T-5s weigh about 75 pounds, give or take a few.
:)[/QUOTE]
So you\'re shaving about 100lbs, maybe a little more, just by swapping the parts...but that doesn\'t include fluid?!? The AOD takes something like 3 gallons of fluid, so that\'s got to be at least another 30lbs on top isn\'t it?
Thread starter #24
JoshMcMadMac
[quote name=\'LuxurySportCoupe\']DS is probably close to 20 if you include the stock cardan and xtra joints. Gotta get these cars on a diet.[/QUOTE]
Not to mention the fact that it\'s a rotating mass, so the \"gain\" is even greater. :yesyes:
Thread starter #25
CaptainZilog
[quote name=\'JoshMcMadMac\']So you\'re shaving about 100lbs, maybe a little more, just by swapping the parts...but that doesn\'t include fluid?!? The AOD takes something like 3 gallons of fluid, so that\'s got to be at least another 30lbs on top isn\'t it?[/QUOTE]
But the flywheel, clutch, and pressure plate make up for some, my FW was about 25lbs.
Thread starter #28
JoshMcMadMac
[quote name=\'CaptainZilog\']But the flywheel, clutch, and pressure plate make up for some, my FW was about 25lbs.[/QUOTE]
Oh, ok. That\'s still a good weight savings, and it would seem that the flywheel/clutch/pressure plate would weigh relatively close to that of the AOD fluid, canceling each other out. Thanks.
Thread starter #32
fulltilt
I had the fun of changing my fuel pump the other day and noticed a difference in some tanks that prob would effect weight. 91+92 LSC= plastic baffles inside tank, some other MK VII of unknown year and model= metal baffle inside. Just for those really looking for every last ounce.
This post is old, but I was wondering if anyone has done this recently? I looked up the nav video converter and cannot find it for less than $350. That is too much. Are there other options? I'd really love to add the backup cam.
Thanks
omarone
Austin, TX
I'm also wondering what options are out there for a reasonable price... I have a 2003 Navigator, any help would be greatly appreciated!
llaugerm
I have put an aftermarket Android Radio in my Navi which I bought for $267 and the steering wheel control works fine as well. I have a rearview camera and a front camera as well.
cpark77
I am trying to replace my thx factory stereo in my 07 mkx with an android unit I can get it installed unit turns on steering wheel controls work fine but I get no sound any help or knowledge of this happening
13
Hi cpark. You should combine this question with the window/moonroof problem thread you started in the other subforum, instead of piggybacking in this thread (about back-up camera installs), for two reasons. First, you shouldn't hijack others thread with your own questions pertaining to a different subject than the OP. Second, this is a Navigator sub-forum and you state you have an MKX.
See my reply in your other thread about your window/moonroof problems and checking fuses.
