Automatic E-Brake Release
4,401
150
I think you have a malfunction, the parking brake should automatically release in R and D. Here is what Ford says: "When the parking brake is set and the transmission is shifted into REVERSE or DRIVE, the gearshift lever position switch closes. The instrument cluster module energizes the electronic parking brake release motor. Once the parking brake is released, the parking brake warning indicator switch opens and releases the actuator. The solenoid is energized only when both the parking brake warning indicator switch and the gearshift lever position switch are closed with the brake pedal applied."
Sounds like another trip to your dealer.
All2kool
1,206
30
48
Portland, OR
My 1996 Cartier will only release automatically in Neutral or Drive, 2 or 1. The car backs up fine with the Parking Brake ON I might add.
TCUltimate2004
323
Concord NC
im having this same issue with my 04, in drive it pops up but in Reverse it stays down. i was thinking its supposed to like in the older cars, sounds like i have a trip to my dealer when i have time to get it checked out. Thanks for the info on it supposed to "pop" up in both R and D
4,401
150
No, I never use the parking brake. But use does keep the system in better working order. When I replaced the left rear parking brake shoes because one lining was separating from the shoe I backed off the adjusters for the left and right parking brakes.
All2kool
1,206
30
48
Portland, OR
Upon further observance, my Parking Brake only releases once the vehicle is placed in DRIVE.
I just consulted with the manual for the 2010 Town Car, and it explicitly states the parking brake will only released automatically in the FORWARD drive gears, not reverse. Not sure if this is just something for the 2010 or not. It seems mine is operating as designed though.
AbeLinc
My '01 Exec only disengages parking brake when I put my car in forward gear, figured it was designed that way, never bothered to look it up (probably because my 2000 Taurus functioned the same way.) I always use my parking brake and would advise anyone to do so, was told years ago by a transmission specialist it's much better for the long term life of the transmission.
All2kool
1,206
30
48
Portland, OR
I believe that is the design as well and if it disengages in R or N, then it's malfunctioning.
bmarler
16
Always use the parking brake. If you saw the size of the park pawl inside the tranny you'd realize why it's a good idea.
The only exception would be if you were leaving the car parked for extended time periods. Block or chock the wheels, e brake off so it doesn't seize and lock up the wheels.
