Audio Amp Compatibility
jonheil
I've determined the problem with my 2014 MKT audio issues is a faulty amp (p/n DA5T-18B849-AE). Online I've found dozens of variants, each differing by one letter or number, but the appearance of the unit and all connections appear to be the same as mine. If I install a unit with a AC suffix instead of AE, will it work? Does it need to get programmed at the dealer?
