Ambient Lighting Issue
Cherga
7
PA
Over the past week I’ve had issues with the blue selection on Ambient lighting. The passenger side footwell light color doesn’t match the rest of the lights around the vehicle. It’s a shade or two off on both blue settings. All other colors match the other LED’s inside the vehicle when changing colors. Anyone else have this issue? It’s under warranty so I’ll have the dealer look at it, just curious if this is a known issue.
RedGeminiPA
73
Altoona, PA
Initially, I had a problem with the lights defaulting back to white. After I updated Sync, I haven't had the problem. You may want to (frustratingly) check Lincoln's website to see if yours needs updated. You could also connect your car to WiFi, and check for updates (Sync 3), though my mom's 2016 could never complete it. I had to manually download to a USB drive, and update hers that way.
Cherga
7
PA
My Sync is up-to-date so that’s not it. I’m thinking the LED has failed. It’s under warranty so I’ll see what the dealer says.
