Advice for removing the Battery Cable Bracket on the back of the Block And the trans ground
1995LincolnTownCar
Hello, I am trying to replace the negative battery cable on my 1995 Lincoln Town Car and I have no clue how to get to the battery cable bracket on the back of the block. I would appreciate the bolt sizes for the bracket bolts as well as the one for the transmission bellhousing ground bolt.
Does the fender ground need a nut on it? Or is it just the bolt? I lost the bolt for the fender ground and I am also wondering if I need a flange bolt or will a standard hex bolt work?
Any help would be appreciated
Thanks,
1995LincolnTownCar
