Adding a new power port with voltage read out....this is a great update!!
TheGodfather
5
Remove the ashtray and remove the old cig and light cobo unit....cut all three wires....( with batt disconnected)tape back and isolate the power supply wire to that powers the light.....use wire cutters to strip and crimp new terminal ends on the remaining two wires ( black is negative)insert and tighten up via the lock ring the new socket.....plug ur wires in....hook up ur battery....make sure u have power....reinstall the ashtray.....your set!!..be sure and use electrical tape to isolate the unused light wire....
Babyburr
60
What year is your Lincoln Town Car?
Theboss
does the power shut off to the USB ports when the vehicle is turned off?
