Abs speed different on right rear
bbigman
Have a 2001 lincoln town car signature right rear abs speed doesn't stay consistent . The axle was replaced and abs sensor checked . tone ring count was same as old one not sure what to check .
Any help would be greatly appreciated.
bbigman
Curious how you can tell one ABS sensor is reading a different speed than the others? What driveability issues are you experiencing?
Biggest issue is speedometer was fluctuating not as much now but still some.I have a scan tool that tells me what each wheel speed is.the previous owner changed the axle I have had abs module rebuilt it was giving a communication error .first changed vss on trans then abs sensor on right rear
