Lincoln Forum: New owner... park assist questions
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. #11
    May 2017
    Chicago Area
    9
    This thread is AWESOME!!!! Ive been having the same darn problem on my 2004! There is a 007 in the junk yard. Maybe I can swap out the ultrasonic for the radar?!? Probably not though. Different plugs. Ill have to get to cleaning the connectors!
  2. #12
    Town, I need diagrams like these for the whole car, where can I get a full set of these images? ready to buy.
    Quote Originally Posted by Town View Post
    Here is a diagram of the Park Assist components on a 2004 LTC. It is the ultrasonic type:
  3. #13
    TecNickal is offline Junior Member My Lincoln(s): 2003 Lincoln Town Car Signature Series
    Jun 2014
    Columbia, SC
    9
    The 2003-2005 is typically having a failure of the module behind the bumper cover. The module on the parcel shelf is not the issue. The sensors in the bumper, unless painted over, are generally fine.
    Something to do with moisture/temperature has an impact on function of the park assist.
    I'm on my third 2003. Each one has had a failed module behind the bumper cover. It's $200 aftermarket, $300 from Ford. Every single one I picked up at the junkyard was the factory one and was junk. The 2003-5 use the same module - Ford parts listing doesn't show this. Its wrong :-) Fixed a friends 2004 and tested this by swapping between his car and my fleet.
  4. #14
    Slick Fan's Avatar
    Jan 2014
    Utah
    398
    Quote Originally Posted by TecNickal View Post
    That's good to know, thanks for posting that!
    That makes me wonder if my Aviator uses the same module, because it's the same year as my TC. I guess I'd better crawl under there & compare!
