2017 Continental Passenger Fuse Box
PJ Dacey
It seems impossible to access the passenger compartment fuse box without major take down of the dash. Is there any hack to make changing a fuse there not a full days work?
4,420
157
Welcome to the Forum.
Here is what the Owner manual says:
Passenger Compartment Fuse Panel
The fuse panel is located under the instrument panel to the left of the steering column.
Note: It may be easier to access the fuse panel if you remove the finish trim piece.
Is it not that easy? I have not tried to access those fuses.
4,420
157
I took a look at mine. It appears the panel has two plastic push pins to retain it. So i would imagine just remove those pins and access to fuse box will be easier. Must be a release mechanism that i cannot see with a quick look.
brucelinc
Minneapolis
The tech at my dealer says it is a major undertaking. They need to access mine as part of the procedure to update the TCU. I am somewhat skeptical based on what it says in the manual.
4,420
157
Can you update us when completed for both problems. The TCU (the embedded modem?) and the fuse box. I can see the fuse box is not as easy to access as it should be.
brucelinc
Minneapolis
I was at the dealer yesterday to have my TCU updated because the Lincoln Way app no longer could communicate with the car. I planned to wait since they said the update would only take 45 minutes or so. After about 1/2 hour, the Service Advisor told me that the tech discovered that part of the update procedure was to first pull the fuse for the TCU for 5 minutes prior to reprogramming the TCU. He said that the fuse box "was inaccessible without removing much of the dash and steering column." It was going to take hours and they would give me a loaner.
I decided that I didn't want them doing that level of disassembly and asked if they couldn't just pull the battery cable for 10 minutes or so and then try to reprogram the TCU without pulling the fuse. The tech agreed to try it "to see if it would work."
SUCCESS! They were able to reprogram the TCU. Everything works perfectly now. I am still not 100% convinced that the fuse box is as inaccessible as they say but at least they got it fixed without any disassembly.
4,420
157
Thanks for the update. After disconnecting the battery did you have to re-program all those settings in Sync3? The radio and hvac settings usually need updating but there are so many other Sync3 settings.
brucelinc
Minneapolis
About the only thing I noticed was that the ambient lighting was turned off and the clock was off exactly 1 hour. I haven't found any other abnormalities. There might be something I haven't noticed but it seems like all is as it should be.
Jeyaar456
5
Yes, it's a nightmare, whatever possessed Ford to position the fusebox there ?
Getting the under steering wheel dashtrim to come off without damaging anything or breaking the clips is nigh impossible, access to fuse box is designed to be as arm twistingly devious as possible, holding a torch with one hand and trying to pop the fuse in requires tiny fingers and long thin forearms, you will drop and lose fuses, so have plenty spares.
Putting the trim back is marginally less traumatic, but as we all know, it never goes back as good as it was before, plus you break a few more fasteners and clips because Ford make shi**y, thin, brittle plastic trim.
Please don't try it unless you REALLY have to.
I believe replacing the cabin filter is a similar doom-laden job from hell.
