2017 Continental and EZ-PASS
GomezAddams
60
5
Central MA
4,526
212
The windshield has something for the rain sensing feature. I don't know how it is applied and whether it reacts with the transponder signal. In the center of windshield there is a rectangular box for the forward looking sensors for cruise, etc so have you tried up above that area? Lots of lincolns would have both the rain sensing and forward sensors.
GomezAddams
60
5
Central MA
Ctrcbob
7
Here in Central Florida, we use either SunPass or E-Pass (not EZ-Pass). My SunPass works fine, two suction cups, about two inches from top of windshield and just to the left of mirror.
C Krohn
357
Fort Worth, TX
I have a North Texas toll transponder permanently mounted on my MKS with rain sensing wipers. No problems. I also have an EZ Pass with a suction cup mount; also no problems. However, I haven't used the EZ Pass in my MKS.
GomezAddams
60
5
Central MA
4,526
212
The owner manual does not describe how the de-icer works. All I could find is the following on how to operate it:
Windshield Wiper De-icer (If Equipped)
The windshield wiper de-icer automatically turns on in low temperatures or when you manually switch the heated rear window on.
The 2017 Escape also has the wiper de-icer feature that operates locally at the bottom of the windshield where the wipers park. It is turned on the same way as your Continental so is probably the same design.
Probably will not affect your Pass if it is mounted high at near center of windshield.
Ctrcbob
7
My Sister and Brother-in-law in New York State, also had a car that the windshield EZ-Pass would not function. They also had to get a front plate mount. Mostly used on the NYS Thruway.
GomezAddams
60
5
Central MA
4,526
212
I spoke with a Lincoln service tech, that used to work in the factory, in the test group. He thought that the wiper deicer was a film put on the entire windshield. The coating is metallic so it can heat the windshield from the bottom up. He was not sure if it would hinder the use of an EZPass. So anyone on the forum have a 2017 continental with the wiper deicer that has an EZPass working or not working, please let me know.
I think that is the old type of windshield de-icer. My son's 2007 Explorer has it and it works great for the entire windshield. It is very expensive.
GomezAddams
60
5
Central MA
jhartz
33
Virginia Beach, VA
New owner and getting used to the peculiars of this car: your post drew my attention. On my Range Rover I had been stationing the EZPass on the sunvisor with rubber bands. But apparently this won't work -- I too have the deicer. Can you add a picture of where you installed the EZpass? Ordered some new velcro . . .
GomezAddams
60
5
Central MA
mustangjeanne
I have an issue with my EZ pass since the day I bought my 2017 Continental. I have even been on the phone multiple times with PennDot to see what is going on. I was getting V-tolls every time I went through a toll booth. My Continental has the new HUD, Heads up Display where the dashboard information is shown up on the windshield. That is blocking my EZ pass from not only being not read, but also not even showing up in the photos taken of my car as I drove through the toll booths. The state has been very helpful with this. I was told the transmitter has to be in the windshield since the state troopers are really cutting down on people running through toll booth without paying. My only workable solution was to keep my holder attached to my windshield and become, as PennDot calls them, a waver. I have to hold my transmitter out of the window, go through the booth then put it back into the holder. It is a real pain in the you know where, but it works. Lincoln knows nothing about this issue since I have brought it up at the dealer multiple times and to Lincoln itself.
EZ pass did recommend I get a transmitter that can be mounted onto my front license plate so there would not be any interruptions. The only problem is you can not move it from car to car. I have 4 cars that use my one transmitter so that is not an option for me.
jhartz
33
Virginia Beach, VA
Just got the bill from EZ Pass for a run up to DC from Virginia Beach: Pass charged correctly at Chesapeake Bay Bridge Tunnel, Chessy Bay Bridge, cross county expressway in Montgomery and Prince George's County and I495 HOV in Virginia. The spot furthest to the top and right, right next to mirror assembly appears to be the sweet spot.
Did get fined for use crossing the Downtown Tunnel in Norfolk, but only because I forget to register this car to the pass.
C Krohn
357
Fort Worth, TX
I have an EZPass from NJ. Used it in the downtown tunnel in a rental with no problem. I got the EZPass from NJ because it didn't require registration to a specific vehicle.
