2011
Adradini
Sunroof when I try to close it, closes very little when trying to close it. But the inside sun liner opens and closes. I’m a new owner and I had to clean the tracks see photos. Red lubricant was tacky.
At a good speed..so I don’t think it’s the motor and now I replaced the switch and it does the same thing, just closes same amount each time so it’s as if something stuck in the track.
I see some wiring rework after troubleshooting my issue thinking maybe it’s electrical but also the sunroof closes to just a
Certain point and it stops like something is blocking it..have tried pushing it as someone is holding the close switch and every other operation of the same switch operates the inside shade. Is there
A
Possibility that whoever did rework some wires connect to this issue. So I could use some advice
