2011 MKX Oil pressure sensor
pholahan
I'v had no luck in locating the oil pressure sensor on my car and I need to replace it. I'm guessing it may be located above the oil filter, which I'd have to remove to get to it. Before I do that I wanted to check here to see if anyone can confirm it's location. Thank you
pholahan
I pulled the oil filter and the sensor is not located on or near the filter housing. Still looking for it's location.
pholahan
If anyone else is looking for the oil pressure sensor, it is located on the passenger side of the oil filter housing, not on the housing itself. You must remove the filter to get at the switch and even then it is a very confined space...enough for one hand only. I used an angled pick to remove the clip and then, after trying several combinations of extensions and universals, I ended up using a 3" extension and turned it with a small vice grip plier. I hit it with penetrating oil first and gave it time to soak. I absolutely could find no information on the internet regarding this, so I hope this helps anyone who needs to replace the sensor.
