2008 MKZ Low Speed Shudder / Vibration
Thread starter #1
slafave
My 2008 MKZ AWD has a low-speed shudder between 10-30mph. Smoothes out at highway/cruising speeds. I've replaced all 4 brakes (Calipers, rotors, and ceramic pads), RH axle shaft (Boot was torn), all 4 tires, both outer tie rod ends. Came on fairly suddenly which makes me think something may have broken somewhere. At a loss and tired of throwing money at it. Car has about 180k miles. Any ideas would be helpful.
Thread starter #2
So, for anyone experiencing the same issue, it turns out this is caused by a bad driveshaft center support bearing. The bearing itself doesn't seem to be replaceable by itself, so the entire driveshaft will need to be replaced. New from Ford, it is about $850. Remanufactured is between $400-$500. Ford quoted a "couple" hours labor for those of you who don't do their own work. Just sharing as a service for others.
