2006 Zephyr Radio Removal procedure
BillM
Mass
Hello,
I am planning on removing the radio from my Zephyr to install an aux adapter so I can play music from my MP3 / Cell Phone. Can somebody please post the FSM radio removal procedure in PDF format?
Many thanks in advance.
OD154
What are you using in order to make an aux input?
BillM
Mass
I used the Pacific Accessory Corp (PAC) PAC AA1-FD4. Bought through Amazon for around $60 I think, PAC wants $100 for it. Also need to buy hte IS335 cables for $10 Very easy to install. Sounds great as there is no modulation / de-modulation going on to distort the signal. Steering wheel controls work with it as well. The only thing that my kids complained about with this car was no Aux jack or USB jack. Problem solved.
http://pac-audio.com/productSearch.aspx?keyword=aai-fd4
http://www.amazon.com/iSimple-IS335-Mountable-Auxiliary-Adapter/dp/B003B01AHS
Liljohn221
Hi Bill,
Attached is the procedure you want.
Take care,
Art
Can I add a thx navigation radio. I just bought an 06 zephyr with the thx radio package. I seen on line that they made a touch screen with navigation. Do you know if a non touch screen navigation system can be switched out with a touch screen navigation thx system.
4,394
118
Welcome to the Forum.
You would likely get the answer you are looking for in the MKZ/Zephyr forum here: Lincoln MKZ Forum / Lincoln Zephyr Forum there are lots of experts that can probably give you great advice.
