2006 Zephyr // Front Right Rearward Control Arm replacement
BillM
Mass
Hi Town,
Do you know what the labor time is to replace the front right rearward control arm? Does an hour sound reasonable, or is it too much? There are only two bolts. Also is an alignment necessary after replacement?
The boot around the ball joint is torn, there is no play in the right front wheel as of yet, but I want to take care of it before there is irregular tire wear. I just put on a new set of Michelins 7K miles ago. The boot was not torn when the tires were put on and the car aligned back in January.
Thx, Bill
SteveB_TX
320
North Texas
Yes, after any type of suspension work, you should get an alignment. As for labor time to replace the control arm... I would guess an hour would be reasonable. Or not. Actually, I haven't a clue! :)
