2006 Town Car Pax Airbag Off Light Assembly
AMCS_P3FE
Purchased a 2006 town car which has a small round hole in the dash to the right of the radio below vent. Assume it is for the pax airbag warning light but do not see any wires behind dash. Anyone have any idea where I can get a replacement or a blank off? Owners manual references light but not exact location and has no pictures or diagrams. Thanks...Tim
4,714
356
83
Welcome to the Forum.
There is a warning light in the location you mention for the passenger airbag that says "pass airbag off". The light proves out at ign on and then goes off. If the front passenger seat is empty the light stays off. The seat sensing system turns the light on when it detects the presence of something or someone that may be in danger from airbag (front and side) deployment. So it sounds like your system is not working properly or the seatbelt is buckled.
You may be able to cut a circle out of matching PVC tape to hide the light if it bothers you and you cannot fix the problem.
AMCS_P3FE
Thanks Town, I apologize I was not really clear regarding the ‘pass airbag off” light assembly, I believe you verified for me that the hole in the dash is probably where that would fit. Just strange the car didn’t have it installed. Good idea about trying to match the color for hiding the hole.
