2003 TOWN CAR Exec
youngmick
My A.C. is blowing out everywhere except the dashboard panels.
Anyone have a clue why, or can suggest a cure or fast fix?
raiderfan247365
145
Western Oregon
As @Babyburr mentioned, you most likely have a blend door actuator issue and should run the EATC diagnostic test (see video below), based on your symptoms you would expect to see error code 1263 which would point to your panel/defrost blend door actuator. Unfortunately there is no quick fix and replacing that actuator will cost at least a couple hours in shop labor plus the part. Good luck.
youngmick
Thanks, fellas, I guess I will have to do the
replacement!
