1999 Continental PCM Location?
paulnj
Where is the PCM located in this car? Is it the module at the top center of the firewall? I am experiencing intermittent Check Transmission/P1744 code. Had a rebuilt transmission and torque converter installed. I would like to check the connections at the PCM but I want to make sure that if I disconnect stuff that I am checking the right thing as I don't want to create new.
Thanks,
Paul
flaokie
16
The PCM is seeing “excessive converter lock up slippage or no converter lock when commanded. “
Don't screw with it.
Take it back to the shop that rebuilt the trans and converter.
