1997 Towncar Wiring Diagram Needed
Thread starter #3
2manylincolns
The Haynes Lincoln manual has some wiring diagrams. What diagrams in particular are you looking for?
Thanks for the reply. I have two areas that I'm interested in. First, the remote lock/unlock circuit; and second, the dash display lights. The remote key fob does not work, and it's not the fob itself. I'm thinking it may be the transmitter, but I don't know enough about the circuit to troubleshoot it. The speedometer and cluster lights work, but some of the control lights don't work.
4,216
91
48
This will be a two part response. The first part will deal with the keyless entry that covers the locks and other features. All key fobs must be programmed at the same time to the car. The key fob sends a wireless message to the Driver Door Module (DDM) that is called the Left Front Door Module in electrical schematics. The descriptions of the components and the electrical diagrams (cell ....) are attached. The key fob programming is in the owner manual.
Good luck
4,216
91
48
This is the second part of the response dealing with the Instrument Cluster. I assume you have the electronic version.
