1997 TC - Do I have Traction Control?
Pasquale
4
I am just getting ready to replace the ABS Pump/Module on my 1997 Town Car Signature Series, but I cannot figure out if my TC is equipped with Traction Control or not. There is a button for 'Overdrive' on the gear shifter, but I am not sure if this is the same as traction control. I checked the book and it only explains what to do if your TC is equipped with the feature, not necessarily whether mine has is or not.
jkeaton
106
Winston Salem, NC
The button on the gear shift lever is for turning overdrive on or off. On my 04, the traction control button is located on the dash to the left of the steering column beside the pedal adjust buttons. Hope this helps.
Pasquale
4
I checked and on the 97’s, the only thing on the left side is the “Steering Hi-Lo” slider. They must’ve added the traction button for your year. Thank you so much for the response!! I will keep researching!
wa9zug
299
6
I don't think you have an on/off button for your traction control. It is on all the time. It works by sensing if one rear wheel is spinning faster then the other and then pumps the brake to the spinning wheel. If you look at your ABS block that is right under your windshield washer, count how many lines are coming out of it. IIRC three lines is no T/C and four lines is T/C. On my 95 I can get on a snowy hill, stop, and slowly accelerate and you can hear and feel it work.
Pasquale
4
I checked and saw the four lines. Thank you so much for the tip! I wish there was a way to remove the module without having to bleed the system... it is only attached by 2 screws and has one wiring harness. The screws are underneath the entire assembly... which is located below the ABS Pump. Even if unscrewed from below, there is no room to pull it out... or is there? Maybe someone has some experience they can share?
