1997 continental strut
J. Perry Garage
hey all, I have a 97 continental with the semi active suspension, it has a blown spring and I haven't been able to find the replacement to save my life here.
Any help finding this thing would be great thanks.
I have been able to find the inner shock, but not even the whole assembly
ArnottDoug
Arnott has air springs for the 97 Continental: http://www.arnottindustries.com/products/lincoln/continental/4-6-liter-v8/1997
Forum members can use code LINCSAVE10 to save up to 10%* off the retail prices on Arnott® replacement air suspension products for Lincoln luxury vehicles. You can place your order online at the Arnott Web Store or by calling Arnott Customer Support at 1-800-251-8993 X 804 Mon – Friday from 8:00 AM to 7:00 PM ET. Orders placed by 2:30 ET are typically shipped out the same day.
*Max savings $75 per order, not valid with any other offer or on compressors, shipping, taxes or core deposits (if any).
Dutchman
You might also want to look at replacing the front springs. I bought custom made +20% (1 extra coil) ones from Coilsprings.com
they located the original Ford drawings and made to to spec. Better quality than the aftermarket stuff from China. The +20 made a huge difference in handling. The stiffer springs are also better for the shocks which are no longer made. I copied part of the quote.
1997 Lincoln Continental
Front - coil springs - +20% rate increase
Pricing: $ 258.60 pair
NOTE: what is the Front - OEM - coil spring part number, of the spring that originally came on your vehicle.
NOTE: the part number will resemble the following: Part# F7OC-5310-CA
Thank you and I await your response
Coil Springs Specialties
