1993 Lincoln Continental Gauges, Speedometer, and Message Display
43fan
Hi all:
My 1993 Lincoln Continental now has the CD player. After I installed the Pioneer CD player, however, the right most display on the instrument panel (the message display one) does not light up at all. The left side is kind of dim (but has brightened up after an hour of use). The speedometer seems to be OK. Any thoughts? Note I did have to take out the dash panel cover, so I did have to unplug the control plugs. But I didnt touch the display itself.
43fan
I was planning on doing that. I used a wiring harness that Crutchfield recommended.
I suppose it is possible that the plug may have gotten unplugged if the wiring is all intertwined with one another.
Ben
Might want to go back in a recheck the plugs and make sure they are all tight. Did you use wiring adapters/harnesses or did you splice into existing wiring for the new head unit?
