1965 lincoln a c blows out air but compressor will not engage ? Any thoughts. New wire or control panel relay ?
Corsart
88
1965 Lincoln a c blows air, but compressor will not engage ? Maybe wire, relay or control panel ? Any suggestions ? Thanks.
Gary, there's a flow chart of rec actions when this happens, the first step is to check the refrigerant level with an a/c pressure gauge. Low freon is the usual culprit here, hopefully a recharge will do it. That's the good news. The bad news is the type of freon used in older cars is being phased out and difficult to find, and in some states a mechanics license is required for purchase.
As an added FYI, its a good idea to run the a/c monthly for a few minutes to lubricate the seals in the condenser to avoid leakage in the future.
The '65 was a gracious, beautiful car from a time when those things were appreciated, you've got a winner there, +1,
Gary lincoln
The '67 was a gracious, beautiful car from a time when those things were appreciated, you've got a winner there, +1,
I charged the unit. Can still buy r 12 on e bay. Expensive as all get out. 30.00 per can. The unit is charged and blows air just not power to compressor . Can run with direct power ?
