1956 Lincoln Premiere oil change help
whosthatlincoln
56 lincoln premiere
im working on a 1956 Lincoln Premiere 2dr hardtop with a y-block 368 and the dipstick stop is broken i need to know how much oil to fill after a service to retack the tab to the dip stick thank you in advance
1,963
986
Phoenix, AZ 85008-1418
If stock, my guess would be 5. Four for the engine and 1 for the filter.
Which means the engine has to be started and run to fill the filter
Generally, that was the crankcase capacity of all FLM engines of the period.
The owner's manual will be a good source too
