Lincoln Forum: 1998 Continental rear view mirror
Results 1 to 6 of 6
  1. #1
    truckerick is offline Junior Member My Lincoln(s): 1998 Lincoln Continental
    Join Date
    Apr 2013
    Niagara
    Posts
    7
    Remove this ad
    Can anyone tell me how to remove the rear view mirror from the windshield mount on a 1998 Continental ?
    Is there a clip or fastener that I'm not seeing ?
  2. #2
    Pasadena Lady is offline Senior Member My Lincoln(s): 2017 Continental
    Join Date
    Oct 2015
    Pennsylvania
    Posts
    225
    You may get an answer here but this discussion is primarily for the 2017 Continental. Go to the Lincoln Community link above and go down to Continentals not in production. I'm sure you'll get an answer there.
  3. #3
    Join Date
    Apr 2013
    Niagara
    Posts
    7
    Oops , my mistake
  4. #4
    Town's Avatar
    Town is offline Senior Member My Lincoln(s): 2017 Lincoln Continental Reserve 2.7 AWD; 2007 Lincoln Town Car Signature Limited (sold)
    Join Date
    Jan 2013
    Age
    72
    Posts
    2,804
    Quote Originally Posted by truckerick View Post
    Lincoln used different mounting techniques according to models. I am told that for the 1998 Continental the procedure is:
    The bracket is held on by a tension spring type clip. Often times you can remove it by placing a pocket type flat screw driver in the little slot on the bottom of the mirror bracket, this will remove the tension and the mirror should slide off.
    As far as removing the "button" mount off the glass just heat the metal part with a bic lighter for about 15 to 20 seconds then grasp the button with a plier and give a slight twist and it should come off.
    In looking at other versions of this procedure it appears that the mirror slides up and off its mounting.
    Hope this helps and good luck.
    __________________
  5. #5
    Join Date
    Apr 2013
    Niagara
    Posts
    7
    Thank you , I'll try that
  6. #6
    rmanduch is offline Junior Member My Lincoln(s): 1998
    Join Date
    Apr 2017
    Dearborn, MI
    Posts
    Remove this ad
    Were you able to remove the mirror from your 1998 Lincoln Continental? Please reply, I have the same problem.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
