07 Lincoln TC speedometer/hud and AC issues
Bateman7
Hello everyone!
So my town car has been having some issues as of late. This usually only happens in the morning but my speedometer just turns off. Some times the gauges stop working and some times they dont. At night it still happens but rarely. I've checked the fuses and cant really seem to find an issue there.
As for the AC, the relay works, swapped with working horn relay. getting good ground at relay spot. getting power at both fuses. no power at the compressor even with a jumper wire to the terminal. The refrigerant is at the proper level, blower motor works, all fans work, but dosent blow cold. Just swapped the alternator (and the waterpump to fix a leaking issue) today.
Any help would be greatly appreciated!
Thanks!
