Roaring sound from rt front wheel. LS6
ThomE
Hello everyone. I have completed a new tire change and for the first few hundred miles, perfect. Problem is that now I can hear a faint roaring coming from the right front tire. I think it may be a wheel bearing issue, not sure but although I know about lubing my truck front wheel bearings, I can find nothing about the Lincoln LS. Any thoughts?
Unlike your rear drive truck, the Lincoln LS is front wheel drive.
The wheel bearings are sealed in the hub. And are not serviceable. Only replaced as part of the hub assembly.
And you would be money ahead by confirming the issue before ordering parts you think are bad.
Hi Action. Just to avoid confusion for the OP and others: The LS was/is rear wheel drive.
Nothing else it really can be. It seems to be a spindle hub type assembly with sealed bearings.
