Lincoln Forum: 1995 Towncar door hinge
Results 1 to 4 of 4
  1. #1
    Join Date
    Jul 2010
    Posts
    Remove this ad
    I replaced the lower hinge of the drivers door on my !995 Lincoln Towncar. Very difficult to get the correct alignment. After many hours of trying different adjustments, i was able to get it to the point that the door opened and closed, except the interior lights do not go out. If I push in very hard on the door they will go out. It just seems like there is no more adjustment in the hinge or the dooe strike. Should both hinges be replaced as a pair maybe?
  2. #2
    Join Date
    Jan 2010
    Posts
    965
    Quote Originally Posted by shanny View Post
    As a rule, YES. Replace both Hinge Pins or both Hinge Assemblies or all of the above.
  3. #3
    Join Date
    Feb 2011
    SRQ
    Age
    27
    Posts
    4
    Quote Originally Posted by All2kool View Post
    Quote Originally Posted by shanny' date='12 July 2010 - 12:20 PM' timestamp='1278966014' post='22386
    Yeah I'm having the exact same problem wit my 96 sig. series. both my upper and lower hinges are severely worn out. how would the you replace both of them? i'm in the process of it right now and its frustrating!! i believe i need to take the front fender off to really access the hinges correctly. if any one knows a good website that can explain it or if anyone has done this them self's. please help me out. i haven't been able to drive in 3 days. bout to drive with no door ha-ha no Just Playing.
  4. #4
    Join Date
    Nov 2007
    Fort Wayne, IN
    Posts
    2,882
    Remove this ad
    Quote Originally Posted by SilverBullet View Post
    Hi Silverbullet,
    I am guessing that the door hinge pins are worn and not the actual hinge assemblies themselves. The pins are the most common wear point. There's a procedure that you can use to replace them without replacing the hinges. You need Motormite part #38410 from the auto parts store. You get two pins for about $6. Only catch is, you have to cut the old ones out with a dremel or other tool of your choice and support the door so that when the pin comes out, your door doesn't drop off the car. You can replace one at a time and should have a door good as new. Removing the entire hinge assemblies is a real bear because it involves removing the dash so you should proceed with this option only if you determine it's necessary to do so.
    Nick
    Past: 1967 Lincoln Continental convertible, 1987 LTC Cartier, 1996 LTC Signature, 1996 LTC DAE, 2002 LS V8, 2006 Zephyr, 2010 MKZ AWD
    Current: 2009 F-150 Lariat Supercrew 4x4
    WANTED: 1967 Continental sedan or convertible
    In my dreams: Continental Mark II
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
