Lincoln Forum: Continental wheel nut torque requirement
Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
  1. #21
    mark95man's Avatar
    mark95man is offline Senior Member My Lincoln(s): 2014 Navigator & MKZ Hybrid, 07 TC Designer, 96 TC, 79 MARK V Cartier, 75+ 69-71 Lincoln MARK IIIs
    Join Date
    Aug 2013
    NY/NJ to Maricopa, AZ
    Posts
    643
    Remove this ad
    Now the question of lug nut torque: When you changed out one lug nut to the "locking" type, did you tightened that new nut to 162 ft lbs as stated in the owner's manual?
  2. #22
    Town's Avatar
    Town is offline Senior Member My Lincoln(s): 2017 Lincoln Continental Reserve 2.7 AWD
    Join Date
    Jan 2013
    Age
    72
    Posts
    2,549
    Quote Originally Posted by mark95man View Post
    If you are talking about my post where I removed a locking wheel nut, you should read it again.
  3. #23
    Town's Avatar
    Join Date
    Jan 2013
    Age
    72
    Posts
    2,549
    Remove this ad
    After I reset the one wheel where I removed the wheel locking nut I did check the wheel nut torque on all 4 wheels. They were 145 ft lbs; so I reset all to 150 ft lbs. My torque wrench is only 22" in overall length and no trouble removing the nuts and setting them. I have used the same torque wrench to tighten wheel hub nuts to 230 ft lbs so wheel nuts are no problem.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
