Lincoln Forum: Gas filler access
Results 1 to 3 of 3
  1. #1
    Join Date
    Dec 2016
    central Florida
    Age
    73
    Posts
    14
    Gas filler access
    Remove this ad
    How do they keep water out of the gas tank with no gas cap???
  2. #2
    Join Date
    Jan 2010
    South Bend, IN
    Age
    71
    Posts
    459
    Does not seem to be a problem.
    '11 MKT 3.5 EcoBoost AWD; '14 Jeep Cherokee Ltd. V6 AWD
    '00 Regal 29' Commodore twin 4.3L
  3. #3
    Town's Avatar
    Town is online now Senior Member My Lincoln(s): 2017 Lincoln Continental Reserve 2.7 AWD
    Join Date
    Jan 2013
    Age
    72
    Posts
    2,348
    Remove this ad
    Quote Originally Posted by edwardt6 View Post
    The system was introduced by Ford in about 2009 models. They used a seal on the inner door and a seal on the outer door (body closure for access to fuel opening). The outer door spring weakened and allowed road debris and water to enter the opening and fall into the gas opening which prevented the inner door from closing causing an evap leak. The problem was resolved for 2013 when much better outer door seals and springs were incorporated, also another door was added to flush mount the inner door with the inner housing so nothing could enter. There is still the inner door. So your 2015 model should have the 3 sealing doors to keep water and debris out and the fuel system sealed to avoid evap leaks when vacuum applied to scour the fuel system.
    Hope this works for you.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Genesis Motors
