Lincoln Forum: Has Anyone Had Trouble With The Electrochromatic Mirrors?
Results 1 to 2 of 2
  1. #1
    FuzzelFox is offline Junior Member My Lincoln(s): 2007 Lincoln MKZ, 1995 Town Car Signature
    Join Date
    Nov 2016
    Posts
    19
    Remove this ad
    I've noticed they seem to turn off and on at random. I played around with a flashlight the other night and if I shine the light on it, it will dim quickly so that the light isn't blinding but then will go back to "day time" mode shortly after. Take away the light and it will dim a little bit. Shine the light on it and again it dims super dark but then goes back to not dimmed at all as if it thinks it's day time.
    I've tried cleaning the windshield around it in case it's reflecting the light back and cleaned the windshield on the outside where the little box is stuck to the window. I'll be able to see after work tonight if that does anything at all.
  2. #2
    Town's Avatar
    Town is offline Senior Member My Lincoln(s): 2017 Lincoln Continental Reserve 2.7 AWD
    Join Date
    Jan 2013
    Age
    72
    Posts
    2,574
    Remove this ad
    The box on the windshield includes the module for the dimming mirrors (inside rear view mirror and driver side outside mirror) that also brightens the mirrors when reverse is selected. I think the sensors that detect the need to dim the mirrors are in the lower part of the inside rear view mirror (on my car they are 2 translucent rectangles placed a few inches apart). The sensors point toward the rear window and pickup excess brightness from following cars with high beam on or mal-adjusted headlamps.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
